0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#631491 03/23/2010 6:05 PM
Hello all, I'm checking all my grounds. I can't find the location of "Engine to Firewall"? Can anyone tell me where to look? I have a new strap but I'm not sure where it should be located. My truck is a 1946 1.5ton.
There was none on the 1941 models. Never heard one on a 46 either.
Ok then, besides the Negative Battery cable, what are the other major grounds to check?
In later years, GM recommended a ground strap between the head and the firewall (with radios) - from a bolt/screw behind the distributor to a fender-brace bolt at the firewall.
You can't have too many grounds. I would ground battery/engine, engine/frame, cab/frame. Straps are cheap and easy to install.
1940 Chevy KC 1/2-Ton
