| | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | I have searched and searched and even went to my local GM dealer and no one seems to know anything about my truck I found the builders tag under the seat today cleaning the cab out and this is what it says maybe I got the wrong size of truck.
Model- 15-43 Serial 2154302133 Engine T3777842 Trim 359 Body Serial 2164 Paint 233
If any one knows anything that can help me plaes help! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy sask42, I will try to break down your serial number for you 2 - year 1942 or 52, must confirm by body style 15 - Chevrolet 2ton, with 224 engine in 1942, 235 in 1952 43 - Chassis with cab, wheelbase 160" [1942], 161" [1952] 02133 is the regular production number I hope that helps some.
| | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | Yes it is a cab and chassis and it is a 42. I thought it had a 216 in it! good thing i haven't bought engine parts for it yet. and i will have to measure the wheel base but 160" looks about right | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy sask42, a 224 and 216 look identical from the outside, the 224 has a 1/16" larger bore. Basically a .0625 overbore of a 216, hope that helps. | | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | I just wish that when it had the new engine installed that they stamped the block cause it has been horrible tring to size it without that stamp
