| | | Forums66 Topics128,180 Posts1,057,148 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | 66 1/2 ton rear drum brakes. You have a rectangular Bar that goes between the shoes, and it has a rectangular coil spring on the front end of it. Where can I find these springs? Part stores and catalogs don't seem to have any record of them. Thank you for your help. | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's going to be a difficult item to get, we even have a hard time getting them for the late model vehicles. The bar in question is called an Equalizer Bar, and it is part of the system that allows the parking brake to operate.
Bill Burmeister | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've found that spring for thr TF series on the HELP rack at NAPA, just need to have one to match or know what it looks like
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Napa shows part number 80448 in their United line. They call them parking brake strut springs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Sorry Johnnyrock, not in this bunch. I believe Longbed55 has the correct one. I tried the local Napa, but unfortunately out here, you have mostly young people working the counter, and if it's not in the computer, you may as well hang it up. I will try that part number and see what I get. Unfortunately, mine are broken on both sides. I have some pieces for shape, but not overall length. Thank's again guy's. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | The 80448 springs do not work, too small in diameter and won't fit on the bar. Unfortunately I had to buy them and order them in to find out. What I found that does seem to work, are early Corvette springs, say from 58 - 62. For what it does, I think they should work alright, and can be ordered from any Corvette parts supply house. | | |
