7 members (FishinToms53, klhansen, Otto Skorzeny, Southerntruck, Mike B, Robert Crandall, Peggy M),
95
Mod | | | Forums66 Topics128,118 Posts1,056,646 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63018 07/12/2006 3:24 PM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I'm swapping out my tired 6 cyl for a sbc(350) and I purchased the V8 gas linkage from one of the classic chevy truck part vendors. If anyone has made this conversion any tips on where to set the bracket before I install the motor would be helpful. | | |
#63019 07/12/2006 8:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive done 2 of them that way. You line it up so the pedal shaft goes through the original hole. The kit is not nessesarily assembled like it goes. It seems I had to take it apart & assemble the parts to work right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63020 07/14/2006 3:49 PM | Joined: Apr 2005 Posts: 2,099 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,099 | If you got it from the Truck Shop it will not work unless you modify the accelerator lever bracket. If you have a FAX number I can FAX you the page from the truck instruction manual that shows this assembly. Fred
#63021 07/14/2006 5:17 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | really pretty straight forward - the bracket goes on the engine side of the firewall where there should already be 2 holes to mount it, the pedal rod w/ the ball on the end goes [toward the bottom] thru the existing hole to hook to the pedal, the threaded rod goes [from the top] straight forward to the carb linkage - hold it in place and you'll see if the rods need to be moved to the opposite sides as wrenchbender points out - like such [shoulda looked at my pics b4 I wrote that] Bill | | |
