1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63009 07/11/2006 11:35 PM | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Hello all, I have a 41 chevy and i am at the point of welding in motor & tranny mounts. I have a chevy small block but no tranny. I don't want to buy a new tranny right now because it is going to be a while before I get the truck running. With that said where can I get a junk 700r4 tranny for mock up purposes or should I just buy the tranny & store it till I need it. Thanks James
If it was easy, everybody would be doing it.
#63010 07/11/2006 11:47 PM | Joined: Oct 2005 Posts: 14 Junior Member | | Junior Member Joined: Oct 2005 Posts: 14 | James, I would suggest you contact a tranny shop in your area. Any tranny shop worth its salt will have one laying around. You dont need one that works, just one that doesn't have a cracked case, for measuring purposes. I am sure they will lend you one.
IF the tranny shop can't help you, contact a wrecking yard. If not them, contact a tow company.
I am planning the same thing. I dont wnat ot purchase a new one, and get the warranty clock ticking, until I am ready to use it.
Tom
Tom ------------------------------ 1953 Chevrolet in progress....slow progress....
#63011 07/12/2006 3:30 AM | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Hey fellas,
I'm here in Pomona. I bought a case for $50 ( guts included in a box.) My drivetrain is done being set up so I don't need the case any more. $40 and it is yours ( I'm planning on keeping the B&M deep ribbed aluminum pan.) $40 ain't a bad deal! The B&M case is actually good, the pump is what took a dive. The guts aren't much good as the seller left them out in the rain. The pump is gone but you're more than welcome to take as much or as little as you need! Send me an email! | | |
