| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I can't get the pistons to move in my 216 motor I got the head off and the pan off..I dont't see any damage..won't move..I poured some penetrating oil on top of the pistions..hoping tomorrow it will loosen up...My neighbour says I should put a block of wood on top of the pistons and strike it a couple of time...What do you think?
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yep . I had a tight ( rusted ) '39 motor . It took a couple of months of penetration oil , block of wood and a hammer . I would give it a hit each day or so as I was going past it . Had to resort to a large brass drift to get the last piston to move  stubborn thing . It all came apart eventually . | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Like Dusty says'+
I use diesel fuel cheaper and gooder than everything else | | |
#6299 07/05/2003 12:46 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | When I took the oil pan off the bottom..I noticed the screen laying in the bottom..How does this attach to the bottom of the pump..I did see some rotted haywire laying there also.. Thankyou for replying to the stuck pistons... I let it soak overnite and found a piece of wood that I thought would do...then every once in a while I tapped them...and what do you know just like you said..slowly they started to move.. Thank You..JD
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | There is a metal pre bent wire that goes from one side of the oil pickup to the other. It attaches in two little holes on the sides. It holds on the screen.
Since oil pumps are only about $45 and your engine sat for so long I would probably just replace the whole thing.
54 3100 with 235 62 flatbed dump C60 with 261
