| | | Forums66 Topics128,089 Posts1,056,138 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Have any of you ordered original style V8 mounts to replace your 235 in a 55 - 59 Chevy 1/2 ton? If so, are the bottom holes in the engine bracket that goes on the front of the engine oval in shape? The ones that I received are slotted but I can't imagine why they would be. If that is normal, please let me know. If it isn't, please let me know where I can get some good ones. Thank you.
Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've used them twice .... the holes weren't ovaled, but it shouldn't matter once bolted up, check it out - the ones from American Classic look correct, but I think mine were from Carter or a Canadian supplier Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive used them twice also & it seems like they were round. Try the bushing in the hole. The raised part of the bushing should fit in the hole. It could be they are alowing for a little mis alignment. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Just to clarify...the holes that I am talking about are the two bolt holes that are used to fasten the engine bracket to the front of the engine. On the brackets I bought, the bottom hole on each bracket has been drilled to make a slot instead of an round hole. Since the top hole is round, I guess it shouldn't matter, but I wanted to check before I accepted them.
Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Larry - it may be that they modified the basic stamping used for the 235, which is quite similar but won't bolt to the 283 properly - assuming you have the engine, just hold the bracket up to the holes and see if the holes match and it puts the pegs at a slight 'spread eagle' - having a bit of adjustment never hurts!
Bill | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thanks, Bill. I see what you are saying about adjustment. They do line up with the front holes in the block. I just wish they had drilled them the way the originals were since the whole front of the engine rests on those little bird legs. I guess I better not get too enthusiastic with the skinny pedal on the 327.
Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 |  it'll be fine, they look wimpy, but seem to hold up well - just make sure over time that the rubber donuts don't deteriorate from oil film and that they stay tight Bill | | |
