2 members (55shaker, Hotrod Lincoln), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
My exhaust heat riser has deteriated over the years and is a mere shadow of itself. I haven't found any replacement parts, rebuilding kits or substitue parts that could work. I would need most all of the parts --- coil spring, butterfly flap to direct air to carb, cover cap for srping, bushings,etc. I'll listen to anyone who has solved this problem!!!
Hi Footbiz,
Not quite sure what a "207" exhaust manifold is, but if you'd check your email I've sent you some info that may or may not help you with your manifold problem and will help you with getting more responses to your posts.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
"chevyb" frequents this site and often has parts for the 1933-1936 207 engines. Most people don't use these age trucks during the winter, so they will be drivable without the heat riser.
