| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62974 07/11/2006 3:37 PM | Joined: Apr 2006 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 16 | My exhaust heat riser has deteriated over the years and is a mere shadow of itself. I haven't found any replacement parts, rebuilding kits or substitue parts that could work. I would need most all of the parts --- coil spring, butterfly flap to direct air to carb, cover cap for srping, bushings,etc. I'll listen to anyone who has solved this problem!!! | | |
#62975 07/12/2006 1:57 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hi Footbiz,
Not quite sure what a "207" exhaust manifold is, but if you'd check your email I've sent you some info that may or may not help you with your manifold problem and will help you with getting more responses to your posts. | | |
#62976 07/12/2006 7:00 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | "chevyb" frequents this site and often has parts for the 1933-1936 207 engines. Most people don't use these age trucks during the winter, so they will be drivable without the heat riser. | | |
