| | | Forums66 Topics128,168 Posts1,057,025 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | In the middle of switching over my drive line and axle on my 1 ton to a standard rear. Pulling apart the rear since I am also cutting a 21in section from the truck, came to realize that the 2 piece drive shaft would not work in this situation and since the transmission does not have a standard setup where I can slide a late model shaft easily into place, I am at a quandary what to do next. It looks as though I would need a 62-63in slip spline shaft in order to fit it in there and from what I can tell that does not exist.
Thoughts.. would a 2 piece work there or by shortening the wheel base is that limiting my option? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Look under a '55 1/2-ton truck and see what it has.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Anyone have a 55 1/2 that they can take a look under for me? Maybe pictures?
Thank you | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I do, but I can't....
My '55 1st GMC Suburban has an SM420 4-speed and a single piece open drive line. You need a similar setup.
I'm not likely to be able to crawl under it again before Fall at the soonest due to some medical issues.
