| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 38 New Guy | | New Guy Joined: Dec 2009 Posts: 38 | Does anyone know where I can get a transmission rebuild kit for my 59 apache. It is a 3 spd column shift, 235 engine. Are there any model and/or I.D. specifics on this trans? Are there any issues I should be aware of when rebuilding it? thanks
Jeff | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Is it doing anything like jumping out of gear that you want to rebuild it? You probably have a SM318 which is a relatively simple transmission to work on. Usually the synchro and the shift leavers wear first and that causes them to jump out of hi gear. I think parts are available. However I watch eBay and grab NOS parts whenever I can. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Geskets, seals, & brgs are available from the parts stores. If it was grinding in 2&3 rd gear or jumping out of gear You will need other parts like Cren say's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
