1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | hello some one sayd to me in germany sayd he saw in the us . a 59 apache with a new frame from a s10 he thinks. can any body tell me wath frame i can use so i just put my box and my housing on it so it looks old but steering suspencion and axls are new . and hopfule with no big change thanks gregor | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The S-10 frame swap is more suited to the AD truck than the Task Force. The track width wouldn't be wide enough. A 73 thru 78 truck frame is probably what was under the 59. Do a search, lots of info on the topic. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Any frame swap is a big change, and even moving the pieces from one frame to an identical one is a big project.
I agree with Yakima that the S-10 frame would be the wrong one to use under a '59. Probably any later full size Chevy pickup frame after the '60 to '62 would be a better swap than the S-10. The front suspension is basically the same from '63 to '87 and the width isn't far off what you need.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I agree with Steve and crew above. An S-10 is way too narrow of a frame for a TF.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | 72-87 works well under a 58-9 http://www.hollisterroad.com/photo.htm about midway down the page is a 59 with an 82 frame | | |
