7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk), 126 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
hello
some one sayd to me in germany sayd he saw in the us . a 59 apache with a new frame from a s10 he thinks.
can any body tell me wath frame i can use so i just put my box and my housing on it so it looks old but steering suspencion and axls are new .
and hopfule with no big change
thanks
gregor
Y
Y Offline
The S-10 frame swap is more suited to the AD truck than the Task Force. The track width wouldn't be wide enough. A 73 thru 78 truck frame is probably what was under the 59. Do a search, lots of info on the topic.
Any frame swap is a big change, and even moving the pieces from one frame to an identical one is a big project.
I agree with Yakima that the S-10 frame would be the wrong one to use under a '59. Probably any later full size Chevy pickup frame after the '60 to '62 would be a better swap than the S-10. The front suspension is basically the same from '63 to '87 and the width isn't far off what you need.
I agree with Steve and crew above. An S-10 is way too narrow of a frame for a TF.
72-87 works well under a 58-9
http://www.hollisterroad.com/photo.htm about midway down the page is a 59 with an 82 frame
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.thoroco.com
