7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | I currently have a 65 C10 with a column mounted three speed(Saginaw) powered by a 350. Is it possible to place a truck 4 speed into this location and use the larger floor "hump" from a 64-66 to cover the area. I have never torn the floor area down this far so I don't know if these three speed and four speed panels are interchangeable? I would like to upgrade and have access to a four speed. I have found after having the truck for 30 years that the three speed is the weak link with this motor. | | | | | Joined: Dec 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 64 | I did this to my 62.I'm sure 64-66 is the same. The access panel unbolts, & you have to drill the spot welds on the smaller panel in front of it to match. Easy cheesy. Then you get a new floor mat !-)
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
| | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | Depends on the year and if your cab came off a larger truck. Find a high hump piece and you might have to add the front cowl section as well.Some of the larger size trucks had a removable cowl section. The 66 cab I picked up, the center section is not removable.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | in my 66 it was changed over to the sm420 4 speed and kept the low hump. a hole was cut and it banged out with a hammer, kept the orig mat. i have unbolted low humps and bolted in high humps several times with no problems. some of the big trucks like the c60's had a pretty flat pan with almost no hump because the cab set up higher. but i find things all the time i haven't seen before, so hopefully your will work with a easy exchange. | | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | Thank you for your input on my tranny questions, I am also new to this group even though I have looked at the website for years. This is consistently one of the best websites for any truck info I have found yet. I have owned and driven this 65 for 30 years and had to rebuild the 350 at the 27 year mark due to a blown head gasket. Other than that, it has been wires, tires, antifreeze! At this point it deserves painting and fluffing again. Prior to this ride I had other Chevy trucks back to high school. On this website there is no shortage of people with ideas, knowledge, or assistance to take care of one's dilemma! And you guys who have been into these projects put a great perspective on the new folks who want to create the truck of their dreams, only as we have seen before to end up on Ebay as someone stated. Thanks for a great website. | | |
