1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Added langdon's HEI to my 250. I have a seperate mounted coil. havent been able to reach tom and want to make sure I hook the external coil up correctly. I have the Hei wired up just want to make sure about the coil. Thanks Mac | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | There should have been a diagram in the box that it came in. The pink wire from the dizzy goes to the "BAT" or + side of the coil. The "hot" wire from the ignition switch also goes to this terminal (Tom supplies a "Y" connector to accomplish this). The black wire from the dizzy goes to the other terminal on the coil.
Be sure to gap your plugs for the HEI and also invest in some high quality HEI ignition wire. | | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Finally heard back from Tom. he was out of coils when I bought my HEI. He is going to email me the picture. I was wondering about a y connector. I already switched the wires. What gap should I have on the plugs? Also where can I tap into for a tach? another y connector for the other lead? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm running .060" on my plugs, they've been in there for 5 years and are a nice tan color. Yes, the tach would tap onto the same terminal as the black lead. | | |
