| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | What was the starter pedal used for. My guess is that there was no solenoid in the starter so the pinion can reach the flywheel ring, and so, you depress the pedal. Am I right? The truck I bought is already converted to 12 volt, has a starter, only start switch and no starter pedal. It the purpose of the pedal is what I proposed, should I cover the hole and forget about it? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you've got it, there's either a starter with foot activated engagement [all 6 cyl up to 1960] or one with key activated solenoid [V8s, 55 up] - cover the hole
Bill | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Thanks. Just out of curiosity, I don't know if my motor is a 248 or 228 (motor number sais 228 but casting says 248. Anyway, since 248 was on 55's up, that is why it was an easy swap to a key activated solenoid or you can install one of the later on, say, a 50's 228 with foot activated starter? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, the solenoid starter was used on cars starting sometime around 1950, then on all trucks after 1960 - all it takes to put the solenoid starter into the truck engines is to match the teeth on the starter and flywheel, which is also a 6V - 12V difference, so it may be your engine came from a 12V that already had the solenoid or all the changes were done at the same time - GMC's didn't start 12V until 56 I believe, not sure how long the 248 went on
Bill | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Manual transmission 6 cy engines in a pickup all used the foot activated starter through 1959. Hydramatic used the key activated starter as well as low cab forward models of 2 ton and up. | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Ok, so the guy did a good job changing the foot starter to an electric activated one. Thanks. | | |
