10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan), 129 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#627317 03/09/2010 8:18 AM
Can anyone help with the specs for a 1954 235 engine. I don't have the info to indicate normal cylinder compression pressure. Thanks for any help on this
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
blanch53 This is out of my old Motor Manual Book ... It is the Tune Up Specifications...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
blanch53,
Another source is the 1954 Chevrolet Shop Manual. It says that the compression test should show 130 psig, +/- 10. This great link, thanks to Keith Hardy, has lots of valuable information.
Hoyt
Ex Hall Monitor
Ex Hall Monitor
Also important, besides the max PSI, is the continuity between cylinders.
I appreciate the response and the links to the online manuals, that will be a great resource for me. Once again this site gets the thumbs up for the help shared by fellow stovebolters.
I have one with 65 - 68 lbs across the 6. Starts good, runs smooth but no power. will rebuild.
dg
