| | | Forums66 Topics128,090 Posts1,056,374 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 19 New Guy | | New Guy Joined: Nov 2008 Posts: 19 | I was wondering if anyone could recommend a factory column that I could swap into my 66 GMC. The original sticks out too far into the cab, has a big diameter wheel and I'm not sure if it has self-cancelling turn signals or they're just broke. Moving the key to the column is not a problem because the whole truck is getting rewired. I've seen some done and am looking for the easiest, best fit, no monkeying around type of swap. Thanks for any help. | | | | | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | I,ve shorted mine two inches. What I wanted to do was to shorten mine and keep the three speed on the coloumn. I done my research and measuring and took two inches between where it mounts under the dash and the steeringwheel. This way all the rest of the column is in the original location. I measured down five inches on both tubes and cut out two then rewelded. The cover got two cut from the center. The stering shaft got cut before the spring and reweleded. It turned out very well and still looks very original to the untrained eye. | | |
