| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hi guys,
I bought a new headlight switch for my truck, because the old one would make the lights flicker a little, and the interior light function didn't work. I installed the new one, but it worked like this...when I pulled it for parklights, parklights came on, so did the tailights. I pulled it all the way, headlights came on, parklights went out ( as they should) but the tailights went out also. The old one, which isnt modified in any way, doesnt do this, so I ended up putting it back in. I have to wonder if the new switch is defective, or if my truck's wiring is that goofed up. | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | Sounds like a little work was done to your wiring harness or a short melted some wires together from your old switch. Do you have a wiring diagram if so you can test the leads coming off the old switch and the new one. I have a wiring diagram from 62 Chevrolet if you want to compare. | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | Found a 1960 Chevrolet Shop manual. 12 GA. Red powers the switch. 20 GA. NATURAL WHITE wire on your light switch harness powers the front parking lights. 14 GA Lt. BLUE goes to your foot dimmer switch. 20 GA. NATURAL WHITE on your switch goes to your Dome Lamp. 20-GA. Orange from the Junction Box powers through the light swich to the... 20-GA. BLACK wire to the tailights. 16-GA. DK. Green from the junction box to the light switch powers the dimmer for interior lights. I could Email you some scans from the book! | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Thanks man, yeah I have that 1960 shop manual too. I didn't even think to look in there, I just thought it was really wierd that the old switch works properly but the new one doesn't. If there was a short somewhere, I wouldn't be suprised at all, because the plastic connector for the wiring to the switch looks a little melted, and if the truck sits for more than two weeks it needs a boost to start, there's something draining the battery. Likely will rewire it if I ever get to restoring it, until then I'll just use the old switch. The dome light will come on if I take one of the wires and ground it to the cab. kinda wierd. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is the way the dome light works. It has a hot lead going to it all the time & grounds through the light switch. The light switch must be well grounded to the dash. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Yeah figured as much. I guess my switch isnt well grounded...or the wire's damaged somewhere | | |
