0 members (), 67 guests, and 5 robots.
Topics128,271
Posts1,058,313
Members48,485
#627776 03/11/2010 12:58 AM
Hello, I am having problems getting the correct water pump for my truck. I have a 1950 Chevy 3100 with a 1955-1957 235 in it. I am in the process of going through the engine and cant seem to find a water pump that matches up with the one that I removed from it. The engine was swapped before I purchased the truck. Any hints on what might have been installed to make the engine swap work?
Thanks, Kenny
It probably had a standard water pump with the shaft shortened and a different pulley. Get a 55-57 pump, press the pulley collar down to match the pump that's on it, cut the excess off with a cut-off wheel. Or you can pay ridiculous money for one that the truck parts vendors have done that to.
Cletis #627930 03/11/2010 1:26 PM
Thanks for the tip. I would have never known that. Both pumps I have tried so far have been about an inch too long so that makes sense.
Thanks, Kenny
