Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Steelonsteel, baldeagle, Rusty Rod, thekid1950, cmayna), 56 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#627058 03/08/2010 6:47 PM
Ifollowed manual procedure to adjust up slack in the steering gear, but its still pretty sloppy. Lmc and some others list it ,but show its out of stock. Anyone have another source for a rebuilt or parts to rebuild it. Thanks Cole
give this fellow a call. http://chevyps.com/
I know that it says p/s, but call him anyway
ron
Hi. I just rebuilt mine, a 62 K-20. I got worm bearings and sector bushings from the truckandcarshop.com. They have everything. You can also get parts from Jim Carter. And Rockauto.com. In my case, I replaced the long sector bushing, which tightened things up significantly. I left the short one in the cover alone. Also replaced the worm bearings, but not the races. My sector shaft was somewhat pitted, I cleaned it up with emery cloth. New seal there too. I adjusted on the bench so there was no play over the center. Filled with 85-140 oil. Overall, a tremendous improvement and no leaks. Fairly easy to do as well.
I also had to do the (closed) knuckle bearings, which are avaialable at Rockauto. I didn't get them there, but got the part numbers there and bought them at a local store. Much more expensive, but I needed them last minute. I got the wheel bearing seals at Rock auto, and the Knuckle seals and wipers at Quad4x4.com, but I beleive they are also available at JC Whitney. The tie rod ends were fairly new when I bought the truck. Now, I have a very tight steering system. Just went through NJ state inspection on Saturday.
CarSteeringwholesale 1-800-399-7845 called them about my 64 K10. They have them in stock. $375.00 + $200.00 core charge + shipping.
1963 C10
