2 members (Hotrod Lincoln, homer52), 93 guests, and 0 robots.
Topics128,049
Posts1,055,638
#627001 03/08/2010 2:01 PM
What is the best way to clean the inside of a gas tank. The tank is out of the truck.
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #627004 03/08/2010 2:19 PM
Ex Hall Monitor
Ex Hall Monitor
That's been discussed a lot in the past Charley. If you do a search using gas tank in the search box you'll find hours of good reading. Good luck. thumbs_up
Tiny #627009 03/08/2010 2:44 PM
Have somebody do it for you. I found it is worth the money.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #627078 03/08/2010 8:33 PM
Eastwood has some good products for this, try them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
MikeE #627086 03/08/2010 9:00 PM
+1
Radiator shops would steam or boil gas tanks in my area. They have the infrastructure to deal with the stinky dregs that usually come out during the cleaning process...something to think about.
Stuart
atomarc #627163 03/09/2010 1:13 AM
Buying a Sptra Premium new tank will be a sure fix and they are quite reasonable.
crenwelge #627189 03/09/2010 2:09 AM
Absolutely Ken, only way to go in my opinion. The time you will waste trying to save a piece of scrap iron just isn't worth it in this case. And there's a real good chance that you’ll have a problem some time in the near future by trying to save a rusted out tank.
The Spectra tanks are hardly distinguishable from the original tanks. I just went thru that exercise Charley with a friends half ton AD. Don't even try to use one of those off shore fuel tanks, they’re nothing but trouble.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #627357 03/09/2010 2:42 PM
Ex Hall Monitor
Ex Hall Monitor
Alas, the joy of having tanks repopped....sigh. I didn't have that option unfortunately. They can be saved but, as noted above, the process can be daunting.
