10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible), 133 guests, and 2 robots.
Topics128,132
Posts1,056,383
Members48,441
#62729 07/08/2006 3:58 AM
Hi all.
I finally found a rearend for my '54 panel. It's a '76 Nova, 7 1/2" 10 bolt, and 3.08 ratio. I am running a 350 with auto. I was told that it would be great on the highway at 80 mph but "gutless" around town. I don't know anything about these rearends and ratios. Will this rearend serve me as a daily driver? It was suggested that I change out the gears. If you guys think this is a good idea then what ratio should I try to replace it with? As always, thanks.
All the best, Ted
3B Offline
Hy Ted, I don't know about gutless. it will have the exact driveability as a 76 Nova w/350 auto. Hope that helps.
How do you drive? If you are running in the stop light drags 3.08 is going to be a disappointment.
I have a 3.08 rear from a '73 Chevelle wagon that was a 350/350 combo and performed fine pulling a trailer. That rear is now under my '55 1st Suburban with a GMC 270 and it is very drivable.
A few years ago I took apart a '78 Monte Carlo that that was factory 305/350 with 2.29 gears in the rear. I drove the car enough to know it wasn't a race car, but didn't seem to have any trouble moving itself around.
Unless you are drag racing or pulling a big trailer I don't think the 3.08 gears will be a problem.
If you don't plan to tow anything 3.08 should be economical. I had a 59 gmc 1/2 ton with that ratio, and it got around town just fine. I kept up with traffic on the freeway at 80mph too. Oh yeah, it had a 6 banger in it, your 350 should move just fine.
If you want better acceleration you could try 3.55, 3.73, 3.90, or even 4.11. By lowering the gears you will sacrifice both top end speed, and economy. If you are running a 700R4 you can go with lower gears. If you are using a TH350 or 400, 3.55 gears would probably be the best city/ highway gears
A 10 bolt seems a little small for your application. Chevy 10 and 12 bolts are not particularly strong axles. They use a c clip design that wears as you drive it. If you were going to spend money on that axle to change the gears, I would look into a stronger axle such as a dana 44, dana 60, or Ferd 9 inch. The 9 inch is the strongest and cheapest to get parts for. The 9 is also the easiest to work on. I have heard that you can swap out the gears in a ferd axle in your driveway in about an hour. You could have 1 ratio eg 4.11 for racing or towing, and another for highway economy.
Check out www.4lo.com it is a 4wd sight that has gear calculators. You can fill in your numbers to see how the gears affect rpms, or speed. Fill in 1 for transfercase ratio, and 1 for transmission ratio... unless you have overdrive.
The Nova axle is not a bad axle for your application. There are better axles available. It all depends on the time and money. Crunch the numbers and ask a lot of questions. Axle swaps can be costly, and you only want to do it once.
Z
ZB3 Offline
Z Offline
My 1989 chevy 3/4 4X4 pickup has a 350/auto and a 3:08 rearend and tows a trailer just fine. In fact I am going to put a chevy 3:08 pickup rear end under my '52. I say go for the 3:08 Have fun, Wayne
i have a nova with a 2.73 behind my 235 with dual carbs and it does just fine in town and out. your tire size also will effect performance. go to www.randysringandpinion.com and play with the calculator to see where you are. hope this helps. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks you all so much. I am relieved that I haven't made any major mistakes yet. As far as how I drive, I'm 57 and want a daily driver. My "need for speed" is over. I just want to make the best panel I can.
All the best, Ted
