7 members (66flea, Gray_Ghost, Charles in CA, Wally / Montana, dt235sd, Christian, 1 invisible),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62711 07/07/2006 5:10 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | 1950 3100. Does anyone have pictures or info on the small parts and seals to put the parking brake shaft back together. This is the curved round shaft that goes from the pedal through the floorboard and is part of the holding mechanism for when the brake is set. This shaft was never in my truck so I do not have a frame of reference. The parts I have are: a shouldered washer, a spring, another flat washer, a rectangular leather type washer and a square thick felt/rubber pad. All of these go over this shaft somewhere. I believe the thick felt pad is the bumper that goes on the end of shaft on the engine side of the floorboard. The assembly manual does not give a great picture or explaination and because the manual deals with 54's, it may not be entirely accurate for a 50. Any assistance would be appreciated. | | |
#62712 07/07/2006 5:17 PM | | Anonymous Unregistered | | Anonymous Unregistered | The foot operated e-brakes are identical for all AD years so the information shown for the 54 should be able to work for you. The green cover assembly manual shows this very well. | | |
#62713 07/07/2006 5:48 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | | | |
#62714 07/07/2006 6:33 PM | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | It helped me, Atomarc. Thanx. That spring between the lock and the floorboard does not show well in the Factory Assembly Manual but it is labeled. I've got mine in the wrong place. | | |
#62715 07/07/2006 7:12 PM | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi Atomarc, Thanks for posting that link, I never knew that it was out there. In my case, I know it will be quite useful! Rick | | |
#62716 07/07/2006 11:47 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | thanks stu
but what that link mis-leads you in viewing is the brake rod does NOT connect directly to the big brake pedal arm. connected to the arm is the lateral extension that is under the floor about 6-7inches to the right (as you sit in the cab looking down) and a short tab is welded to the extension. the brake rod connects to that tab.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#62717 07/08/2006 5:14 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Thanks for the info as well guys....but let me ask another question:
I can't get my parking brake to "catch" and hold on my truck...got an exploded drawing describing that?? Everything is hooked-up but I don't hear the familiar sound of the e-brake locking and holding when you put your foot to it.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#62718 07/08/2006 5:27 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Blue 50,
Part # 4.603/Lock needs to have crisp edges where #4.603/Bar passes through it. This lock bites into and wedges the bar. You don't like exploded drawings???
Stuart | | |
#62719 07/08/2006 9:21 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Stu,
I love exploded drawings!!! Thanks again for the info. I'll take a file to the lock and sharpen-up the edges...
Chuck
Blue 50
#62720 07/09/2006 9:36 PM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Thanks Atomarc, the diagram is great. | | |
#62721 07/10/2006 6:58 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | OK...decided to take the assembly apart and get a better look at it and promptly sheared both bolt's that hold the lock guide to the floorboard. Looks like they have never been removed. The spring is also bent and will need to be replaced too.
I thought there might be some teeth on the shaft but it looks like the e-brake uses pressure against the shaft that holds it.....is that the way it works??
The manual doesn't offer much help either. Can anyone 'splain how the system works and ways to adjust the tension to keep the e-brake engaged?
Chuck
Blue 50
#62722 07/11/2006 2:01 AM | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | I had to fool with mine for a while before I got it to catch. The key is in the "angle of the dangle". What I mean is you may have to bend the lock arm to a steeper angle. for it to catch. That is what fixed mine.
Roy | | |
