| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 30 New Guy | | New Guy Joined: Oct 2009 Posts: 30 | Are 10-20's and 11-22.5's the same diameter or height? Mert | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, approximately. See page 45 in this catalog http://www.accuridewheels.com/completeversion.pdfHowever they are not interchangeable on the same rim, which you probably already know. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | They're close enough to run a tube-type 20" and a tubeless 22.5" on the same hub. The trucking company where I used to manage the shop did it routinely. Tires have to be pretty compatible so far as profile goes, but the -.5 wheels were intended to be a direct replacement for tube type wheels. For instance, 15" tube type and 16.5" tubeless are supposed to interchange. 16 and 17.5, 20 and 22.5, and 22 and 24.5 are all supposedly direct-swap replacements. Jerry
| | | | | Joined: Oct 2009 Posts: 30 New Guy | | New Guy Joined: Oct 2009 Posts: 30 | | | |
