5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
#624550 02/28/2010 10:06 PM
Apprentice
Apprentice
Does anybody have a part number for a paper element for the AC air cleaner on a 51 216? it's about 6" od and 1 1/2" high. I know Jim Carter and some others sell them but I would like to get one locally to save on the shipping. Thanks
Take your air cleaner in to your local auto parts store and see if they will help you find one...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Manufactures put out specs on filters as I have seen the in catalogs, the only question today is can that info come up on a computer, or does your FLAPS have that info.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Caution: I bought the Jim Carter version and was disappointed. It's the right OD but it's too tall to fit in the stock air filter housing. NAPA sells the same thing at half the price (about 1-3/4" tall). I originally bought at NAPA, and I returned it, because I assumed the JC version was a better fit. I don't remember the NAPA part number.
Does this help. Be sure to read what Denny posted.
https://www.stovebolt.com/ubbthread...mp;Main=10560&Number=68507#Post68507
-Tom
1950 Chevy 3100 w/ 1956 235
I revised the dimensions of that Carquest filter.
dg
Denny G
Sandwich, IL
Apprentice
Apprentice
Thanks guys. It looks like these are all about the same dimensions. The Napa 2375 has round hole mesh that looks closer to original. The Fram web site crosses over to about every filter made.
Car Quest 87373
Fram CA 77
Napa 2373
Napa 2375
Tuley, if you're truly concerned about correctness, this is an original spark arrester element; it has regular or standard expanded metal sheet on the outside and on the inside round perforated steel sheet, the center mesh is aluminum.
http://www.pbase.com/dennygraham/image/122450138/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Apprentice
Apprentice
No I'm not concerned with original look, I have a filter like you show but it's starting to fall apart. I want a paper because I feel it will do a better job. I mentioned the napa filter looked good for other peoples benifit. Thanks to all who replied.
