3 members (Peggy M, Pre '68 Dave, 1 invisible),
101
Mod | | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Today I tried to pull the transmission out of my 41 with 3 speed, 216. I took the ball joint apart and moved it to the rear and undid the universal then I tried to remove the transmission with no luck at all. What is the trick?? I gave up and pulled engine and trans together, both had to come out anyway. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Here's the trick I used. Get yourself a couple of 4" long bolts the same size as the upper bolts on your trans. (only threaded part way) Now cut off the heads and cut a slot in the cut off end for a screw driver. Take out the upper mounting bolts and replace with the new long "studs" you just made. Take out the lower bolts break the trans loose and slide it back on the upper studs and lift it out through the cab. You can replace it the same way. Just slide it in on the studs and put in the lower bolts, then the upper ones. Hope this helps. George | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | That sounds good but mine would not come back far enough to clear the input shaft because the rear was hitting on the bell and the universal. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | I lifted up the torque tube as high as possible with one hand and pulled the transmission with the other. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I'm not clear on "tried to remove the transmission with no luck at all". Does this mean after you took the universal apart, the yoke wouldn't slide back into the torque tube clearing the end of the transmission allowing the torque tube to be lowered or raised out of the way of the transmission removal. Or does it mean the transmission is siezed to the bellhousing?
Hopefully this will knock things off center and you will get some more feedback if your are still having the problem of removing the transmission from the bellhousing.
I'm also trusting you removed the 4 bolts from the transmission to bellhousing connection. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I got it out, but I pulled the engine and transmission together, I didn't know how much pressure I would dare put on the torque tube so I didn't get rought with it, How much will it move before damaging something, mine only moved about 2 inches. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | To gain a little extra clearance I hooked a come-a-long from the differential to rear frame cross member and pulled the torque tube back. I had learned from this site to always have your jack stands under the frame and not the differetial. | | |
