| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Does anybody know of any supplier that have a back-up switch,I have a 55 2 series 3 on the tree they mount on the steering column and are activated by the gear shift shaft ,when put in reverse, I have the mounting bracket, perhaps someone has found another switch that will go in the mount. and do the trick Thanks | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | does anyone know of a switch for a 1950 4 spd? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | There was a switch and a bracket that mounted to the shift handle, and made contact only when the trans was in reverse. It's a pretty rare item, IIRC. I've seen OEM parts list that show the 4-speed switch and bracket, but I've never actually seen one in use. Jerry
| | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | hotrod, do you think that 4spd switch for a 50' is something i could get from the stealership? | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | These switches show up on ebay from time to time. They look like a little bullet.
I bought an NOS set 8-10 years ago. It had the set up for both the 3 speed and 4 speed. I have the 3 speed (column shift) set up on the 55 2nd and the 4 speed (SM420) on the 48 3100.
Back-up lights are nice when in the city. It lets city people know when you are backing up. City people don't have much sense.
Dennis -there is nothing stronger than the heart of a volunteer-
