1 members (Steve_H),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | I can see the end in a few months...I hope! I have a few misc. questions that I hope can be answered. When I got my truck it was missing a few parts so I have nothing to reference. 1. I am about to order a brake light switch...does the arm in the picture simply work by rubbing on the pedal when it is depressed or am I missing something? 2.I'm going to order a heater switch. I have only one wire hanging from the heater motor...should there be a ground too? 3. I have 2 copper ground cables. One goes from the battery to the chassis and the other goes from the chassis to...???...the starter motor??? 4. I bought a cigarette ligther socket and knob. Does anyone know where to get the piece to secure it to the dash...and any needed wiring? 5. Does anyone know where i can buy the piece that is a filler for a truck without a radio? Thanks for the help! Bob | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | 1 brake switch works by being actuated by the pedal 2 heater motor is grounded, only wire is power 3 battery to body/frame...frame to starter attaching bolt (ground) 4 cig lighter should have a unscrewable shell to clamp thru the dash hole... 5 try Jim Carter's or Filling station...check out parts suppliers in links.... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'll try to answer here, I'm more of a Task Force guy. 1, the switch for the brake lights (I beleive is the same as TF), The arm rides on top of the brake pedal arm, when the pedal is depressed, it releases the switch arm (It's spring loaded) making it contact. 2, the hater is grounded through the heater housing. 3, One ground cable should go to from the battery to either the cab or chassis, preferrably the cab, the other goes from the engine (starter bolt is a good mounting point) to the same cab/chassis mounting point as the other cable. It serves as the engine ground. 4, unsure about the retainer, i would think that it would be included with it, again, I'm not 100% familiar with the AD trucks. Wiring is relatively easy, 1 wire ran to a power source, usually a constant hot. If you're only going to loks, no wiring needed. 5, E-Bay or the swap meets. Also, check out the Swap Meet forum. The radio block off isn't being reproduced, but you might be able to get one from someone that is installing a radio in theirs.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Radio delete panel is what it is often called. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's it George, I knew there was something askew with what we were calling it. Thanks for recalling that. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | You guys are great! thanks for the help. Time to go shopping on e-bay. Thanks, Bob | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I see the radio-delete panels on eBay just about every week.
Don | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Looks like there is a buy it now on ebay right now Bob. Appears to have the bolts with it, they are kind of hard to come buy, I had to make my own on the lathe at one time.
There was a guy on ebay motors that was making the plates new, can’t seem to find him now. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | I found my radio delete plate at the body shop in their "lost" pile! Still looking for the bolts for it though. I might just try to rig up some old radio knobs to make it work for now. Once I get done spending money to get this thing done i might splurge on a radio. Thanks again for the help. I hope to make some real progress this weekend...nobody is here to interupt me! | | |
