8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible), 81 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
Does any one know the length difference between the short tail shaft 3 speed transmission and the longer transmission used in the 55 - 58 pickups.
The short 3 speeed is 17" from the front of the case to the end of the tail shaft housing. The longer trans is 22". Internal parts will interchange as well a swapping the tail housing/mainshaft from one to the other.
Fred
