| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | Does anybody have a part number for a paper element for the AC air cleaner on a 51 216? it's about 6" od and 1 1/2" high. I know Jim Carter and some others sell them but I would like to get one locally to save on the shipping. Thanks | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Take your air cleaner in to your local auto parts store and see if they will help you find one...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Manufactures put out specs on filters as I have seen the in catalogs, the only question today is can that info come up on a computer, or does your FLAPS have that info. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Caution: I bought the Jim Carter version and was disappointed. It's the right OD but it's too tall to fit in the stock air filter housing. NAPA sells the same thing at half the price (about 1-3/4" tall). I originally bought at NAPA, and I returned it, because I assumed the JC version was a better fit. I don't remember the NAPA part number. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I revised the dimensions of that Carquest filter. dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | Thanks guys. It looks like these are all about the same dimensions. The Napa 2375 has round hole mesh that looks closer to original. The Fram web site crosses over to about every filter made.
Car Quest 87373 Fram CA 77 Napa 2373 Napa 2375 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tuley, if you're truly concerned about correctness, this is an original spark arrester element; it has regular or standard expanded metal sheet on the outside and on the inside round perforated steel sheet, the center mesh is aluminum. http://www.pbase.com/dennygraham/image/122450138/large Denny Graham Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | No I'm not concerned with original look, I have a filter like you show but it's starting to fall apart. I want a paper because I feel it will do a better job. I mentioned the napa filter looked good for other peoples benifit. Thanks to all who replied. | | |
