8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#624282 02/28/2010 3:29 AM
Does anyone know of a source of reproduction hood hinges for Deco COE's? I think they are the same on the AD's but not positive. I have one that is not too bad (I would use it) and one that is really badly rusted and pitted. I would like to replace them but haven't found any as of yet. Any help greatly appreciated.
Chuck
CayoRV #624324 02/28/2010 4:31 AM
I have several good used '47-'53 sets, but i'm not all that sure they will interchange with the '46, & earlier. I don't think they will. They are not reproduced. You may want to place an ad in the "Parts Wanted" section.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #624329 02/28/2010 4:38 AM
I'm not sure either, I just was looking at some pic's on the web and they look to be similar. There are rights and lefts on the 46 and earlier with 2 bolts that hold them to the cowl and 3 bolts to attach to the hood with a clutch head hinge pin. If I had a good chrome shop within a hundred miles of me I might have them repolished and rechromed, no such luck though. Guess I'll have to figure out "plan B".
CayoRV #624758 03/01/2010 6:51 AM
There are none reproduced that I know of. I'm not positive, but 99% sure they do not interchange with the next generation. One thing you might consider that looks close is some of the same era car trunk hinges. They are notably different, but when mounted, probably not all that far off. Just a thought that ran across my head when I considered looking for a nice set.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
CayoRV #626362 03/06/2010 2:43 AM
MY HINGES WERE VERY RUSTED WITH LARGE PITS, SO I JUST SANDED THEM DOWN WITH A BELT SANDER TO THE POINT THE TAPPED HOLES BROKE THRU THE TOP AND I HAD TO WELD THEM AND SAND SOME MORE. THEN I PAINTED THEM WITH CHOME PAINT. I DON'T HAVE THE $$ FOR THE REAL THING
