8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle),
106
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62453 07/02/2006 8:09 PM | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | Hey guys- I'm an eager to learn newbie who just bought a 59 261 with the intention of rebuilding it. Tore it down when I got it home, and it looks like the rod bearings sat and lightly rusted to the crank at some time in the past, then spun for at least a few times when restarted (not by me!). The crank doesn't look too bad (havn't mic'd it yet, but no grooves). I can't feel the wear on the inner connecting rod surface, but I can see it. I don't see connecting rods for the 261 listed in any of the catalogs I've looked at so far- (Patricks, Langdons, internet search, etc) Do you think these are an "automatic replace" given the spin, or can these be mic'd OK or be reconditioned? Anybody have a suggested source for these? | | |
#62454 07/02/2006 11:18 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | they can be resized at a machine shop,,brian | | |
#62455 07/03/2006 12:56 AM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Most any engine rebuilder will have the facilities to resize, or maybe exchange at a reasonable price. | | |
#62456 07/03/2006 6:57 AM | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | Thanks Brian and KENC-
What do you mean by resize- do they machine them? I've seen rod bearings that are listed by amount of machining on the crank, but have never seen them listed for oversize rod journals.
Thanks, -Warren | | |
#62457 07/03/2006 2:55 PM | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | To resize a rod, they cut a small amount off the cap where it mats to the rod. This makes the hole smaller and eggshaped. Then its onto a hone where they resize the hole back to OEM spec's. Its a real common operation done at any decent machine shop. Joe | | |
#62458 07/03/2006 6:23 PM | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | Thanks Joe H-
That's so cool! I never thought about doing it that way but it makes perfect sense. Thank you for the info- One of my goals of having this hobby is to learn as much as I can about the nuances and subtleties of engine rebuilding. Thanks again for your help
-Warren | | |
