3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
#624224 02/27/2010 11:20 PM
Hi, Does anybody know what a set of jumper / booster cables looked like in 1947 ?
Would the cables be rubber covered with copper spring clamp ends ? Any help on the description would be appreciated.
gill
6 volt or 12 volt
Redryder pix
My Hotrod
I'm not sure jumper cables were commercially available in 1947. All I can remember during that era were home made cables. They would have been for 6 volt because that's what all light vehicles were. However, since almost all cars were manual transmissions then, push starting was the preferred way of starting was considered dangerous. Jump starting was considered dangerous because batteries were not sealed and hydrogen explosions were common.
I agree.
Without a vehicle, just a couple of people pushing could start a car with a clutch "pop". With most cars and trucks having real bumpers, vehicle push starting was the way to go. Even as automatic transmissions came into being, a vehicle push was common, but at a faster speed.
I honestly don't even remember jumper cables until the late 60's or early 70's.
I thought it would be a really small needle. dance
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
You could push start an automatic at 30 MPH by dropping it into Lo, till around 1965. Then they did away with the tail pump, and jumper cables became common.
Gill - the "copper spring clamp ends" you likely have in mind are welding ground clamps, you could use them to "fake it", but this style is about as "vintage" as you get, and you I doubt you'd find'em new now
Gill,
If you are looking to get some that would be appropriate for 6 volt, and copper clamps, they are available if you look online. Below is a link I found for some, and the clamps look a lot like the ones in squeeze's picture. They're 4 gauge - the ones for $86.00.
Samantha
Battery cables with copper clamps
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Thanks for all the good information, it all makes perfect sense.
Gill
Y
Y Offline
Here is the closest thing I have found next to push starting
Vintage jumper Cables
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
