3 members (Hotrod Lincoln, 2-Ton, 1 invisible), 63 guests, and 4 robots.
Topics128,021
Posts1,055,353
Members48,420
#62414 07/01/2006 5:40 AM
My truck has a 235 with stock 3 speed. If I were to try to install a Tremec 5-speed would it bolt up? Is the bolt pattern on a 235 similar to a small block?
#62415 07/01/2006 4:20 PM
Not even close. You will have to buy an adapter from Buffalo.
#62416 07/01/2006 6:26 PM
I think the Tremec 5-speed uses the same bolt pattern Chev trucks started using in 1948, and cars started using in 1955.
My Blog
#62417 07/01/2006 9:11 PM
Riding in the Passing Lane
If the trans. has a separate bell housing & is for Chev. it should bolt up.
1972 Chevy c10 Cheyenne Super
#62418 07/01/2006 11:08 PM
The later 5 speeds like the Tremac are designed to use a different bellhousing, it won't bolt up to your existing part. you'll need an adapter.
Bill Burmeister
#62419 07/02/2006 1:52 AM
I just looked on the Tremac site and there is no mention of any adaptor if you are using it with the bellhousing I listed above.
My Blog
#62420 07/03/2006 1:33 AM
Hmmm. Now that I've looked at the site you mentioned, I see I am mistaken. I thought they had the same pattern as the Mustang, I did not realize there was a different version for Chevy.
Bill Burmeister
