5 members (Gdads51, moparguy, 55shaker, Bill Hanlon, 1 invisible), 410 guests, and 4 robots.
Topics128,162
Posts1,057,049
Members48,463
#623825 02/26/2010 6:09 PM
I have a '48 Canopy Express 3100 and I am trying to find a correct tail/stop light for it. None of the aftermarket truck suppliers carry one for a canopy. Does anyone have a pic of what it looks like and maybe I can find something that will work. Thanks.
Mike
OLTrucks
Unregistered
OLTrucks
Unregistered
Well I can share this with you. Out of the 1929-57 Chevy master parts. This is tells you the mounting parts are the same as 41-52 wagon , 47-55 canopy express and 47-55 suburban with end gate.
Group 2.670 PARTS, Real' License Attaching
41-52 STA. WAG.,
47-55 CAN. EXP.,
47-57 SUB. w/ENO GATE...BRACKET,license . . . 5938846
Here is a link to a picture but you cant really make much out of it.
I think I may have one of these and just not the housing for the tail light or the link. I see if I can dig it out and get a pic of it for you.
Mike,
Go to my Flickr page below and I have posted several pics for you.
Watch ebay
http://www.flickr.com/photos/canopyman/
Justin
The light is the same for Suburbans 1947/55 and almost the same for the task force years 1955/59 with the clamshell tailgate. The only real difference is the lens (glass vs plastic) and the rod that allows the light to pivot and stay in the down position.
They go on ebay for around $100 - $300.00
The difference between the station wagon and the suburban tail light, is the base, the rod and the rod bracket. Canopy man has the correct light and if you notice the base is round and the bracket that extends beyond the light. That is where the rod goes into. The station wagon base is more square and the bracket is shorter. Everything else is the same, the R-13 light base, the chrome trim, the glass lens, the license plate holder and the hinge piece that the base attaches to.
The station wagon light will fit, but without the correct rod bracket and rod, it will not pivot correctly.
BTW: Welcome to the Bolt. We are becoming a group of CE owners. I think there are at least 6 owners on here, including myself.
I had to purchase several light assemblys between GM wagons and trucks to complete a very nice assy for my truck and going to put my OG on the shelf for a back up for the just in case...then took my left overs and completed them and resold them, long way around but worth it.
Went ahead an added the acc. side lamps, after being called several times by friends saying I was asking for problems due to the lack of proper lighting in the rear. The last thing we need is to get rearended with a CE.
My finds where on Epay, Craigslist, Stovebolt and 67-72chevytrucks by lots of surfing.
Good Luck on your search. Neal,
- NEALS49 - 2LOW4U -
"RECYCLE BUILD A HOT ROD"
"SUPPORT YOUR LOCAL CLUB"
1949 GMC 100 Canopy Express On my Flickr
1949 GMC 100 SWB Deluxe Cab On my Flickr
1949 Chevrolet 6400 yard work truck
[b]1949 GMC 250 LWB 9' Deluxe Cab
On my Flickr
A whole lot of pics, 12K+ ..On Flickr Photo Group 47-55 AD
My Facebook Page NEALS49 MY GARAGE
GMONIZ, I am buying a 48 Wagon tail light to go on my 48 burb. Will my burb rod work correctly with the wagaon tail light? I do not have the wagon rod.I have the correct base and rod from my burb but will probably just swap and put the entire assembly on until I can find the correct one, unless I can get the wagon one to pivot correctly. I don't have the wagon assembly yet.Thanks
