Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (TUTS 59, 68ironhead, tclederman, 2-Ton, wilbur53, 3B), 138 guests, and 5 robots.
Topics128,281
Posts1,058,476
Members48,490
#623510 02/25/2010 6:23 PM
My mechanic suggested to me that i may want to consider installing a radiator overflow tank for my 216 engine. I realize its not original, but its advantages could out-weigh the negatives.
What do yall think? If i get one, i could get an early model overflow tank that doesnt look too modern.
Thanks for your thoughts
'51 Chevrolet 3100 216 5-Window
A tank will stop coolant losses. I saw an original coolant overflow tank in the swap meet lately but it seemed a bit pricey to me. Let us know what you decide to do and pictures would be cool too.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=616193#Post616193
http://www.chevsofthe40s.com/shop/s...p;dept=Truck&searchtype=FT&Go=Go (they have one style that is a reproduction for the original accessory - it's no less expensive than the one at the link above).
I have never had to use an overflow tank with a 216/235/261 engine. You fill the radiator to within an inch of the top and run the engine for 30 minutes after it has warmed up. Let it cool down and then check the level. A little fluid might overflow until the correct level is reached. When cool, the coolant level is about 2-3 inches below the filler opening.
Until 1954, the radiator cap on a truck was 0 pressure; later, they were 4 psi to 7 psi, depending on the year and size/duty of the truck. A high-pressure radiator cap on these trucks would most likely cause leaks at a few weak points in the system. Shops/people who are used to modern, high-pressure, cooling systems almost always recommend overflow tanks for older vehicles.
Be carefull not to use a high pressure cap you'll end up popping your heater core they were never made to take the pressure I put a 4 psi. cap on mine and once I ran the engine a few times it does not overflow anymore.
Pete
Tim,
Will a pre 54 raditor hold the higher pressures of a late model sbc if you put a high pressure cap and an over flow on it?
I was thinking of using the original 41 1.5 ton radiator with an electric fan for my sbc conversion.
1937 Chevy (converted to 4x4)
1942 Chevy G506 1.5 ton 4x4
1958 Mack B model (on Chevy 1 ton 4x4 frame)
1969 Dodge Charger
1987 K30 Crewcab
Empty 40 and a wire hanger.
Bodyguy,
I do not know. I'd have a radiator shop give it a long-time pressure test.
Better yet: Wait to hear from some one with first-hand experience (and/or who might know if a bigger radiator might be needed with a small black V-8).
Originally Posted by Bodyguy
Tim,
It didn't work for me, too much pressure. I bought a 4-core from Champion Radiator off ebay. In hindsight I could have got away with a 3-core.
1953 Chevrolet 3600
This good info guys, thanks. So what is your opinion on using one? If i drive my truck often (2-3 times per week), would it be a good idea to have one, or is it unnecessary?
I can handle the 40.....where did ya get the hanger...most I see are now plastic?
1951 restoration on website
http://www.hanklong.com
Kevin, if all is right with your truck and your not using it to haul a ton of gravel up a hill to the building site, there really isn't any need for an overflow on a stock 216. People tend to over fill the radiator and when it pukes out the extra after warming up they think they need an overflow. Keep the system clean and the level just above the baffel in the radiator when it's cold and you shouldn't have any cooling problems. As was brought up earlier, you can gain a little higher boiling point by running a 4 lb. cap but DON'T go any higher, the system will only take about 8 lbs before the tubes in both cores (heater and radiator) begin to distort.
Denny Graham
Sanwich, IL
Denny G
Sandwich, IL
Thanks for the insight. I was considering it because a buddy of mine used his old down flow and an electric cooling fan in his sbc conversion in his 49 International.
Anybody else tried this?
1969 Dodge Charger
1987 K30 Crewcab
