7 members (Shardean, DannyW, 68ironhead, Eisenholtz, 3800GUY, Shade Baby, cmayna),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 32 New Guy | | New Guy Joined: Jan 2010 Posts: 32 | I have a 56 gmc 3/4 i am looking for opinions on what could be done to make the truck an easier ride. Anything from using present front suspension with a shock to complete front change. thanks tom, | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Are you saying there are no shocks on the front? Should be. And yes, it can be changed to a Nova, Camaro, MustangII, airirde, lots of stuff available. Be prepared to spend some bucks if you do it . Do a search on front suspensions and you'll uncover a lot of things. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | If you don't mind it riding a little lower you could take your front springs out, take them apart, clean them up, grind out any dishes or grooves, remove 2 or 3 leaves, reassemble them with poly-liner in between the remaining leaves and use a good set of gas shocks. Won't ride like a new car but you'll be amazed at the difference | | |
