3 members (Otto Skorzeny, jmoore, 1 invisible),
94
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I know it's been some time since I've posted here, but I've been working diligently on my 1950 3600 as spare time allows. I reached the point that I was ready to drop a driveshaft into my truck and was resigned to the idea that I would have to have one custom made. I was pleasantly surprised to find that a 65-68 Chevy Impala driveshaft will fit nicely, and cost me a whole lot less on Ebay. The yoke is a perfect fit. The only change is the rear universal joint has to be changed to a crossover joint (part #348 from Napa I believe). I just wanted to share this info with those of you who are looking at dropping a small block into a 3600 AD truck. FYI, the driveshaft is 62" center of U-joint to center of U-joint. Good luck, and thanks to The Bolt. This board has been a tremendous help to me over the last 7 years. | | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I knew I'd forget something. My truck has a later model 14 bolt FF rear end in the original location, hence the need for the crossover joint. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Good work! Thanks for sharing with us!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks for the info,50-3600-guy.
I've got a similar problem in that I have an 81 C3 Vette TH350C and driveshaft. Obviously that will require lengthening! The problem I have is I'm using an 86 Firebird (Borg Warner) rear axle and have discovered the UJ sizes are different too. I ordered a 'crossover' UJ from Speedway and it doesn't fit! Can you (or anyone else for that matter) tell me what UJ I actually need? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I would measure the cap diameter of the driveshaft and the cap diameter of the axle then look on the napa website for a match. The napa website gives the dimensions of the u-joints online. Measure with a caliper, not a tape measure (for accuracy). Good luck! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks....all I got to do now is find a NAPA store over here!  Joking apart, their site will be useful in working out the sizes. I'll have a word with the guys doing my driveshaft, at least that way I'll have some idea what I'm talking about!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Dumb question: what's a cross over joint ? Can someone post a picture ? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Just a word of caution re. long drive shafts, be sure to have a professional balance the piece. A buddy of mine made a long driveshaft for his 3/4 ton pickup, it came apart on a downhill and launched the truck over the side. He survived but the rig was totaled. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Dumb question: what's a cross over joint ? Can someone post a picture ? Basically it's a universal joint that has different bearing cup sizes on opposing axis'. This allows you to 'adapt' for example a Pontiac pinion yolk to a Corvette driveshaft.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Just a word of caution re. long drive shafts, be sure to have a professional balance the piece. A buddy of mine made a long driveshaft for his 3/4 ton pickup, it came apart on a downhill and launched the truck over the side. He survived but the rig was totaled. Drove a car with a badly balance driveshaft once.....never again!  Most driveshaft shops I've dealt with balance them as a matter of course. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2009 Posts: 42 Apprentice | | Apprentice Joined: Sep 2009 Posts: 42 | might not be a bad idea to include a driveshaft hoop. It holds the shaft off the ground in case of failure.
Brian Hill
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | might not be a bad idea to include a driveshaft hoop. It holds the shaft off the ground in case of failure. Good idea, a friend of mine found out.....the hard way! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Jock, find a truck driveshaft place. They will take care of you. Most Caterpillar facilities can help as well.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks Scott,I found a place just 6 miles away... They specialise in Trucks/agricultural equipment.
They gave me a 'ball park' estimate,the price seemed pretty fair.
| | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Since I'm using a whole driveshaft from another vehicle, and it's not being cut or modified I would assume it's already balanced. That being said, I know what can happen when you "assume", so having it rebalanced is a good idea. The same goes when acquiring a junkyard shaft. Just good sense. Adding a loop is also a good idea when utilizing a long shaft, and I intend to do that as well. Thanks to all for some good input. Safety First!
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mine is a 51 3600 with SBC and a 10 bolt Camaro rear. I had a drive shaft shop that knows their stuff to build mine. Cost $110.00. and worth twice that to me.
~Jim
