Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Peggy M, MNSmith, Steelonsteel, 1 invisible), 311 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#623541 02/25/2010 8:58 PM
I have a 56 gmc 3/4 i am looking for opinions on what could be done to make the truck an easier ride. Anything from using present front suspension with a shock to complete front change. thanks tom,
Are you saying there are no shocks on the front? Should be. And yes, it can be changed to a Nova, Camaro, MustangII, airirde, lots of stuff available. Be prepared to spend some bucks if you do it . Do a search on front suspensions and you'll uncover a lot of things.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
If you don't mind it riding a little lower you could take your front springs out, take them apart, clean them up, grind out any dishes or grooves, remove 2 or 3 leaves, reassemble them with poly-liner in between the remaining leaves and use a good set of gas shocks. Won't ride like a new car but you'll be amazed at the difference
