3 members (PAUL Berardi, Paul Mullen, stlcardinalsguy), 157 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#623230 02/25/2010 12:54 AM
I was wondering if I could take advantage of some Stovebolter knowledgeabilty and ask if the 235 is a superior engine to the 216 as it seems that so many of the old trucks were updated with the larger engine.And I hear the term babbit bearing pounding engine with the 216 could someone elaborate on the meaning of what that refers to? And was the oiling system different?
fifty3 #623237 02/25/2010 1:17 AM
fifty3 #623239 02/25/2010 1:24 AM
The 216s and 235s were very similar up to 1953. In that year there were differences and for sure in 1954 they changed to a modern full pressure oiling system. No 216s were made after 1953. The 216s and early 235s used dippers on the connecting rods and spray nozzels to enhance the rod lubrication at higher RPMs. The oil pressure on the 216s and early 235s was a lot lower than the full pressure motors. The connecting rods did not use insert bearings but had the babbitt attached directly to the steel rod. Here is a good link with lots of information:
Chevy Six features
1951 1 Ton Completed
Y
Y Offline
I think the 216 is a fine engine, the newer 235's are just that, Newer. Full pressure lube, a little more power, and higher RPM's. That is why I think most people change them out. For the higher speed driving. the 216's you cannot run at the higher speeds with the stock set up. I run 3 216's and 1 early 235(low pressure bored out version of 216 developed for WW2 I believe)
They do everything I need them to without issue. I hear the "pounder" nickname and I thik it refers to the clanging noise for out of spec bearings, I am sure someone can elaborate hear that has a litle more knowledge than me.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Thanks for all the info.
fifty3 #623522 02/25/2010 7:30 PM
I'm ashamed to admit I was one of those guys who said my orig. rebuilt 216 was fine. I used the truck alot but was never happy with the 216. She now has a nice full pressure 235 which is one he!! of a nice motor.
Too Tall #623664 02/26/2010 3:04 AM
24601
Just be advised that if you are contemplating removing a 216 and replacing it with a later (full pressure) 235, it is *not* a form/fit replacement. There are some mods that need to be done in order for the 235's to fit without butchery of the radiator shrouds. Check out our Tech Tips for more info on this.
Not hard (I did it smile ), but still something to keep in mind.
V/R
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
