| | | Forums66 Topics128,051 Posts1,055,730 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hi, Here's my problem: I have a 1953 6400 2 ton truck. I "think" I have a 235 in her. But the casting number which is located on a machined pad between the distributor and starter has the following stamped on the pad " LEAI029985". The character after the A looks like a capital I. I have been to several sites that have casting numbers and I don't see anything remotely close to what I have. Can anyone help me solve this? Thanks. Phil Stewart
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That number is the Serial number, not the casting number. The casting number will be found towards the front of the engine on the RH side near the bottom of the block. Unfortunatly, the codes I have only cover up to 1 ton, so I can't really decode it too far for you. I can tell you that the L in the code does equate to 1953. I do know there is a site with the codes, but I do not know the site name.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think that is the casting number. The casting number is raised as it was cast as part of the process. There is one on the block, I think on the passenger's side near the bottom front and one on the head. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | "LEA" refers to a 235 53' , built at Flint, for the 6000 Series trucks. The rest of the engine serial number is the sequence number at that plant starting at 1001. http://www.stovebolt.com/techtips/enginecodes.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hi Randy, Thank you for taking the time to check that out for me. It is greatly appreciated. | | |
