4 members (Shaffer's1950, Hotrod Lincoln, 1955 1 Series, TexasA&M48Truck), 127 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#622961 02/24/2010 3:33 AM
OK
Here is one. I am putting my front end on an S10 frame with chevy SB. The question is I know it mounts of the cab. Are there points along the frame to mount the rest of the front end either making the mounts or using the inner fenders with modifications to hold the front end up and mount it solidly. I am sure someone has done this. Any and all help will be appreciated.
Bill, I have not done the S-10 conversion but the fenders mount to the cab and the radiator frame the inner fenders mount the same way and not to the frame. So I guess the question would be are you intending to use the original radiator frame in the conversion?
I have put a complete 46 on an 87 S-10 frame. Thanks to E-Z Swap it was a easy build.
E-Z Swap
I am thoroughly impressed with the kit. I am sure you can get just the part of the kit to mount the radiator support to the frame. It is engineered to do just what you need. The front fenders mount to the front of the cab and to the radiator support and no where else.
Pic of radiator support kit
If you have questions contact me.
Frank Cox
Cox Custom Cars & Restorations
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
Alright
I have the radiator support original
EZ swap does not list just the radiator support adaptor.
Can it be made. Anyone with a drawing or pic maybe some measurements, I hope
Give them a call or send an email. I am sure they can send you what you need.
Frank Cox
Cox Custom Cars
