6 members (3800GUY, cmayna, 52GMC35424JD, JW51, Rusty Rod, 1 invisible), 98 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#622847 02/23/2010 9:11 PM
8
8 Offline
I have a 58 3200 that was set up with turn signals. On the rear they used a separate set of lights for the turn function....I would like to combine the turn with the regular tail light.......is it as simple as just tapping into the brake wiring or am I missing something?
86Brat #622863 02/23/2010 10:13 PM
H Online: Content
Combination stop/tail lights require a selector switch built into the steering column switch assembly. If they use the brake lights for both functions, one brake light will burn constantly on a stop, while the other one flashes to indicate a turn. No turn, both lights are on to signal a stop. The early aftermarket turn signals didn't incorporate that switch. They came in "4-wire" and "7-wire" designs, and the ones with 4 wires cannot be set up to combine turn and brake lights on the same bulb. The "7-wire" switches have an input wire from the flasher, another from the brake light switch, a "pilot lamp" output wire that goes to an indicator light on the dash, and four wires to the bulbs, front and rear, right and left.
Hotrod Lincoln #622873 02/23/2010 10:38 PM
8
8 Offline
Thanks for the help, I have an older style, will have to look at it more closely
