Combination stop/tail lights require a selector switch built into the steering column switch assembly. If they use the brake lights for both functions, one brake light will burn constantly on a stop, while the other one flashes to indicate a turn. No turn, both lights are on to signal a stop. The early aftermarket turn signals didn't incorporate that switch. They came in "4-wire" and "7-wire" designs, and the ones with 4 wires cannot be set up to combine turn and brake lights on the same bulb. The "7-wire" switches have an input wire from the flasher, another from the brake light switch, a "pilot lamp" output wire that goes to an indicator light on the dash, and four wires to the bulbs, front and rear, right and left.
