5 members (KEVINSKI, cmayna, TexasJim50, Gdads51, 1955 1 Series), 49 guests, and 0 robots.
Topics128,080
Posts1,055,946
Members48,430
#622670 02/23/2010 3:51 AM
Apprentice
Apprentice
What is involved with a 250 swap, is it only the engine mounts that need to be changed, the front mount for a side mount? Is it also longer in length than the 235? Thanks.
235 is taller than 250; makes a little change to the exhaust pipe connection & changes fan location @ radiator. As well I think its a little longer; witch will also change fan to radiator relationship. (Anybody feel free to correct me here if I'm wrong) you will also need a different bellhousing to match the new engine up with your transmission.
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
ctrworker #622891 02/24/2010 12:08 AM
Riding in the Passing Lane
A lot depends on what year truck it is going in.
1972 Chevy c10 Cheyenne Super
And what transmission you plan to use.
OldSub #622950 02/24/2010 3:10 AM
Apprentice
Apprentice
Sorry, its to go in my 51 chevy deluxe car , it currently has a 3 speed tranny but I would like to upgrade at the same time to a T-5 5 speed from a S10.
That makes it easier. Someone makes V-8 mounts for that car, wish I could remember who. I'd buy the V-8 mounts and a transmission cross member and use whatever bell housing came with the motor and go that route.
The 230/250 will mount just like a Chevy V-8. The 292 is different.
OldSub #623513 02/25/2010 6:33 PM
Apprentice
Apprentice
Thanks Oldsub, does anyone know if it is longer than the 235 (or sits farther back towards the firewall? Thanks
The 250 is approximately 1" longer than the 235, measuring from the back of the block where the bellhousing bolts on, to the front of the cramkshaft pulley. Both bellhousings are about 6 1/2" deep. Positioning of the assembly front/rear with custom motor mounts will be necessary due to the differences in mounting hardware.
