5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#622506 02/22/2010 6:13 PM
Apprentice
Apprentice
Hi, looking at buying a 700R4 to put behind my 283 that I'm getting ready to put in my 1962 SB. Has anybody done this installation and can tell me what's in store for me? The main thing that I'm concerned about is the transmission mounting position... will it line up or am I going to have to move it forward or back, or get a after market mount.
62MUCH #622592 02/23/2010 12:18 AM
What transmission are you replacing?
I suspect the answer is that you need an aftermarket transmission mount, or perhaps will have to make one. '60, '61 and '62 are different that what was before or after, and I'm not sure of the details on one of those.
Early 283's did not have provisions to mount the starter to the block so you will want to check that out. There is an aftermarket spacer plate available from various suppliers that can be used with late model transmissions.
Fred
