0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#622390 02/22/2010 5:29 AM
I have and 46' chevy with a pretty worn paint job and a few questions about rat rod paint jobs.
Can I just put a protective coat over the paint job that won't give it a glossy finish and keep the paint job looking flat like a rat rod is suppose to look like?
This subject has come up before, you could try a clearcoat with a matting agent added.
As long as you can seal the surface with a waterproof barrier your 'patina' should be preserved.
I would have liked to do the same,but the 'importer' threw about 2 gallons of red oxide primer on mine!
More pix on Flickr.
Eastwood and other Suppliers now have an Egg-Shell finish paint that is formulated to be a top coat and supply the look you are after.
1952 Chevy Shortbed
Photos in Photobucket
The way I understand it, surface rust will continue to oxidize underneath clear coat. The clear coat will blister and peel in the surface rust areas. Some products also yellow when exposed to sunlight (I think POR makes a clear coat rust inhibitor that is (was?) not UV protected and would yellow.
Some guys apply grease (not sure of type) to preserve patina.
Norm Grabowski Lives close to me (If you don't know how that is just goolge him) and on his old truck to keep the patina looking good he uses linseed oil.
I'm not sure what a rat rod is supposed to look like, but if you like the way the paint looks now just leave it alone.
Steve
'49 3800
'52 3600
'57 3100
I'm trying to imagine a drive down a dusty road in a truck covered in linseed oil.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
You know...Ratty!
Mike
Ex Hall Monitor
Ex Hall Monitor
Using Rat Rod and Paint Job in the same sentence is considered an oxymoron isn't it? grin
I had an old 49 Dodge PU that I would just "paint" once a month with Diesel fuel. The cab was crushed by a huge pine tree 25 years ago. Last week I went down back looking for something to put on the back of my 36 to replace the dump body and dug out the bed. Aside the wood being long gone the Orig. paint and bed were just as they were back then. Here's a picture http://i890.photobucket.com/albums/ac102/chiefbobber/36010a.jpg.
I'm sure it isn't a real Green thing to do, but it did preserve the metal and the paint. It was something an old farmer I worked for used to do.
