8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible),
67
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62205 06/26/2006 5:06 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | Hi, I am new to Stovebolt and I have a question about the motor that I have taken apart. There are no oil nozzles in the oil pan. The oil pump goes straight into the block. Am I missing something? It is a 235 from 1958-1960 truck I believe. It had a recent (?) rebuild with new .030 over pistons and such. I removed the engine just to restore the engine bay and dress up the motor in my 1950 styleline, not to fix anything since nothing was broken. All cylinders were 120-130 compression and just a very little white puff of smoke when starting. But as the story goes. " While I was there" I decided to look at the internals. The entire inside of the engine looks great. Do I have a problem? Any reference info would be great. Thanks for any help. Kent :confused: | | |
#62206 06/26/2006 5:38 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I don't know what you mean by oil nozzles in the pan. As far as I know the pan is just that - a pan. The oil pump is near the rear of the block, bolted to it with a pick up which drops into the oil pan to pick up oil. There could be baffles in the pan to keep the oil from gathering in one spot when you are accelerating or braking. Maybe I am missing something here and certainly some of our talented and experienced members will set us straight. | | |
#62207 06/26/2006 6:00 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | 235s after 1953 were full pressure oiled and the pans don't have troughs for splash oiling or nozzles to direct oil to the troughs. The rods and mains are oiled through the crankshaft. | | |
#62208 06/26/2006 6:30 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | Originally posted by boerdoc: Hi, I am new to Stovebolt and I have a question about the motor that I have taken apart. There are no oil nozzles in the oil pan. The oil pump goes straight into the block. Am I missing something? It is a 235 from 1958-1960 truck I believe. It had a recent (?) rebuild with new .030 over pistons and such. I removed the engine just to restore the engine bay and dress up the motor in my 1950 styleline, not to fix anything since nothing was broken. All cylinders were 120-130 compression and just a very little white puff of smoke when starting. But as the story goes. " While I was there" I decided to look at the internals. The entire inside of the engine looks great. Do I have a problem? Any reference info would be great. Thanks for any help. Kent :confused: Thanks Baldy. What has me confused is the manual for 1958-1962 235 ci engines show a set of oil nozzles. see picture linked. [img] http://pg.photos.yahoo.com/ph/boerdoc/detail?.dir=18db&.dnm=692c.jpg&.src=ph[/img] How do you check that all oil passages are flowing freely? | | |
#62209 06/26/2006 7:19 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | | | |
#62210 06/26/2006 8:19 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | i clicked the link,,,i don't see oil nozzles in pic. just a pick up screen that attaches to oil pump.....oil pump is nu. 24 n 20 in pic. the pick up screen is nu. 22..or sits rt. under the nu. 22... | | |
#62211 06/26/2006 8:57 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | darin367 In the link the #23 is called oil delivery pipe. It is to the left of the oil pump, halfway to th end of the pan. There are nozzles that come off of it. I just noted that the title for the drawing says "Typical" maybe this is for something else. Thanks for all the help. Kent | | |
#62212 06/26/2006 11:49 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | the picture shows rod bearings so you are looking at a full preasure oil engine so there are no oil tubes ,,if you think the drawing shows oil tubes then the drawing is not correct...doc | | |
#62213 06/27/2006 12:27 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the only "pipes" is where the pump sends oil to the gallerys - if it was a runner, it ain't broke, so nothin to fix! Bill | | |
#62214 06/27/2006 6:50 PM | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | boerdoc Welcome to Stovebolt land! Your 58 235 does not require the oil nozzles or troughs that the older motors had. Your rod caps do not have dippers and the crank shaft is drilled with an oil passage to each rod throw. Your good to go!
Professional Novice
#62215 06/27/2006 7:45 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | Thank you for all the help. Kent | | |
