0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | I have an 87 350 with injection, I want to change to carb, for my 40 chevy..manifold I know and new carb. what else??Where can I find the Intake I need. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | You'll need a distributor for what ever ignition system you decide to run also, Points or HEI in either Stock or AfterMarket form. As for the intake, you can run a stock SBC if you like to any aftermarket one you can buy for your application. Lots of local parts store carry after market stuff, you can get a stock one from the local boneyard if they have them or buy a stock or aftermarket one at a swapmeet..joe | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | and a fuel pump, electric or a manual will work if your block is machined for it...joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The center bolt holes on the intake are straight up on those engines. You will have to get an intake designed for it. All the speed equip. co's have theme. Like Summit Or Jeds. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You can elongate the hole on an older intake slightly and the bolts will work fine in the center. Put a couple of flat washers under the bolt head. Really not a bad swap at all. Get either an older HEI distributor or a points style distributor, elongate the center holes in the intake, make sure the carb is good. There was one engine I installed that had the block cut for the fuel pump, and the hole drilled for the pump push rod, but the cam didn't have the lobe on it for the fuel pump. Had to use an electric pump with it. | | |
